Finn_Arne
Jan 12, 2024Aspirant
WiFi Range extender WN3000RP V3
 I have used this model for several years, but have now got another router. How do I change the password and are there other data I must changes in order to make it work with the new router?
- Jan 12, 2024
Factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMkI'd probably look at upgrading it though. Its an old/slow extender. Unless you're just using it for IoT devices, its going to be super slow.
Jan 12, 2024Guru - Experienced User
Finn_Arne
Jan 13, 2024Aspirant
Thank you Plemans
I will fix it :-). I use it just for reaching out to the garage and the battey charger for my car, so I think it is fine
