dalber
May 29, 2018Aspirant
WiFi Range Extender
I have a friend that has a structure on his property that is getting sporadic WiFi. He calls it a shed but it is really his man cave. Would an extender help him or would he need something between his ...
DexterJB
May 30, 2018NETGEAR Moderator
Hi dalber,
Welcome to the community!
An extender is ideally used in between the router and the location where the dead spot is. If there is an area in between where an extender can be placed then it may work. However, you may consider using a powerline instead. Here is the link for NETGEAR powerlines.
Dexter
Community Team
