Fivestars5
May 01, 2021Tutor
WiFi range extender
I have a new broadband provider and router they provided, Technicolor dga0122nlk. I can connect to my extender via wps My devices can see the extender but when I try to connect by typing in my router...
Fivestars5
May 01, 2021Tutor
I have downloaded a WiFi network manager and reset the extender. The manager sees NETGEAR_EXT, the device links lights, click on the _EXT and it opens a browser, msn, type in mywifiext it takes me to a netgear page saying “ you are not connected to your extender’s network”. So what do I do now?
May 01, 2021Guru - Experienced User
try hardwiring the ex2700 into your pc/laptop that you're using for setup. Just make sure to disable the pc/laptops wireless so its not defaulting back to the wireless connection.
- Fivestars5May 02, 2021TutorWhen I turn off the laptop WiFi and hardwire the ex2700 the sSIDs are grayed out in the network manager and there is no device light on the ex2700.
- plemansMay 02, 2021Guru - Experienced User
Is the ethernet port enabled on the laptop?
If you shut off wifi, the wireless ssid's will be grayed out/not visible.
You're trying to use the ethernet connection to the router.
- Fivestars5May 02, 2021TutorI have managed to get onto the installer and setup a password and it is all working now.
Thanks for your help
