AlanGotts
Nov 19, 2018Aspirant
WiFi range extenders - EX3700 and WN3000RP
Hi - any advice/assistance would be brilliant if at all possible
I have two Netgear WiFi range extenders [EX3700 and WN3000RP]
I have them set up brill to extend my home network - these with diff...
Nov 19, 2018Guru - Experienced User
AlanGotts wrote:
What I am trying to organise is for devices that access these extenders to ONLY have access to the internet (from my main router which is obviously on the home network) and not be able to access any other devices that are on the home network
Is this possible?
What you need to do is set up a guest WiFi network on the router. Then configure the two extenders to extend the guest network, and not your main WiFi. The extenders have to be in extender mode - it won't work if they are in AP mode.
Note that the devices connected to each extender will be able to reach each other. However, they won't be able to reach devices connected to your wired network or your router's main wifi network.
AlanGotts
Nov 20, 2018Aspirant
Many many thanks - advise really appreciated
I will investigate further ref Router and Guest [I think that I have another possible solution - if the Router doesn't offer the Guest functionality and rather than buying a new one with that], I also use devolo powerline adapters to extend the wifi throughout which I believe also have WiFi Guest functionality - so I could always use this if I get a deadend with the router
Thanks again
Wishing you a good rest of the week
ASll the very best
A
