HalRivera
Apr 04, 2022Aspirant
WiFi Range Extenders with PoE
Good Morning all... I'm looking to set up in an old-old house WiFi ceiling extenders(connected to CAT6 w/PoE switch) that has PoE power. I only find AP's. I want to extended the existing WiFi netwo...
Apr 04, 2022Guru - Experienced User
I don't know of any extenders that support POE from netgear.
I'm not sure why you're not wanting to use an access point. If its hardwired in, an access point is going to provide higher performance than trying to use an extender.
- HalRiveraApr 04, 2022Aspirant
But! will the Access Point 'extend' the router/WiFi network or will it create it's own?
- plemansApr 04, 2022Guru - Experienced User
Depends on what ones you use and how you do it.
the insight line of access points have a mesh function with other insight devices.
But not with consumer routers/extenders.
but you're kind of caught because you're wanting it ran with POE.
