GraniteKnoll
Sep 07, 2020Aspirant
WiFi Range
Can you connect more than one range extender to the same router?
Sep 07, 2020Guru - Experienced User
You can.
I'd recommend doing it in a star pattern and not daisy chained though.
Star: extender<--------router------->extender
daisy chain: router------->extender------>extender
reason why is standard extenders take a 50% speed hit just based off how they function. So by the 2nd hop, its best possible speed is 25% of what the router has.
- GraniteKnollSep 07, 2020Aspirant
Thank you!
