Michelhaddad
Aug 06, 2020Aspirant
Wifi repeater on an ap mode
Can i connect a repeater to a linksys switch with an ethernet cable and get a wifi connection from it
Michelhaddad
Aug 07, 2020Aspirant
I sent a screen shot of a power line adapter that i want to buy online in the product description it's written ap mode and repeater mode, but when i asked the provider he told me that it doesn't work
Aug 07, 2020Guru - Experienced User
so you've got a totolink repeater/extender and a linksys switch. Where does netgear fall in this?
- MichelhaddadAug 07, 2020AspirantI just wanted to know if it works or not (a repeater connect to a desktop switch) will it give me a wifi connection
- plemansAug 07, 2020Guru - Experienced User
You're literally on a netgear forum asking if a totolink device works with a linksys device?
Maybe you'd be better to ask on the totolink forum what their devices work with?
theoretically it should work if the totolink has AP mode and the device works as it *should*.But again, I don't have that device or that switch
