XT500fred's avatar
XT500fred
Wifi repeater with LAN output?
Hello,
Is there such a thing as a wifi repeater with ethernet LAN output?
My neighbour has a Netgear DG834G, I can just about pickup his wifi signal with a wifi usb adapter, and he has agreed to let me use his wifi signal. I know i can boost this signal reception with a better antenna.
I have 2 computers and would like to connect them both to the internet. Is it possible to convert a router to a repeater so the wifi antenna is the signal input, and the LAN ports are the signal outputs? Or is there a repeater specially designed for this?
Yours,
Fred.
  • Technically - repeating is a wireless only solution - if you want wireless to wired you need a wireless bridge, not a repeater.
  • Thanks for the replies chaps.
    That Wn2000rpt looks the business, but it looks like you can't attach a different antenna. I need to attach a high gain antenna, on the end of about 1m of cable, and position the antenna on my window so i can pick my neighbour's wifi signal.
    Is there a Netgear wireless bridge that allows a different antenna to be attached?
    Ta,
    Fred.
  • Don't really know how to use this forum... but we bought a new NetGear wireless router & I can't seem to find the "Key" to set up my wireless printer. Any suggestions?
    Ta,
    Fred.
    Most of your home end n router don't have external antenna capable
    Technically speaking mus ISP do not allow neighbors to get free internet. Usually customer of ISP are the one gets in trouble with fine. If you even pay your neighbors that is worse as welll. :)
    Read manual
    Support.netgear.com , get the manual:)
