wangzx0417
Oct 23, 2020Aspirant
WiFi Router (RAX80) to replace my Huawei HG659 router?
Hi, I am considering to buy tthe RAX80 to replace my current Huawei HG659 Wifi router provided by my nbn provider TPG. But not sure if it is 100% compatible, can anyone please help advise here? ...
wangzx0417
Oct 25, 2020Aspirant
Thanks for your advice.
The reason I was considering the wifi router replacement was I thought the wifi router, being a AC router would be the bottleneck of the network speed. Wifi 6 (AX) was meant to be at least 1.5 faster than AC plus other features.
Now I am re-considering the Mesh systems
Regards
Max
Oct 25, 2020Guru - Experienced User
AX is faster if you have AX devices.
How many devices do you have? it can help with speeds if you have a lot of devices broadcasting at the same time
- wangzx0417Oct 25, 2020AspirantAbout 10 devices connected simultaneously. Most of them do not support AX yet.
Regards
Max
