Sotmo
Mar 24, 2014Aspirant
Wifi Signal Drops Consistantly with main router and 2 access point routers
Hi, I have the following setup at home: I have a main Netgear N300, router and have linked another Netgear N300 + a D-Link to extend my WiFi signal. I am using the same SSID and have done all the n...
Retired_Member
Mar 24, 2014How are they all connected? I would think the mac list would need to be added to each device or what's the reason for using it on router only. Most say that Mac filtering is a waste of time and doesn't add much security.
you might use unique ssid to trouble shoot then change it back
