Sotmo
Mar 24, 2014Aspirant
Wifi Signal Drops Consistantly with main router and 2 access point routers
Hi, I have the following setup at home: I have a main Netgear N300, router and have linked another Netgear N300 + a D-Link to extend my WiFi signal. I am using the same SSID and have done all the n...
jmizoguchi
Mar 25, 2014Virtuoso
If you are going to use "access list" in two devices connected ethernet you need to use access list on both device. Main router with access list may not work when device are connecting to other AP.
Also for future reference you need to post under router and extender . Post are based on products you won and not network method
http://forum1.netgear.com/forumdisplay.php?f=32
