Sotmo
Mar 24, 2014Aspirant
Wifi Signal Drops Consistantly with main router and 2 access point routers
Hi, I have the following setup at home: I have a main Netgear N300, router and have linked another Netgear N300 + a D-Link to extend my WiFi signal. I am using the same SSID and have done all the n...
Retired_Member
Apr 10, 2014If you use unique ssid when one drops out the client should connect to another. Assuming you connected to each one prior.
Like I said in post #2 use different SSID to test.
If you're seeing all three AP's dropping wifi signal It would point to the client card. If you're saying you loose internet but still connected that's another story .
So which is it?
So which is it?
