Sotmo
Mar 24, 2014Aspirant
Wifi Signal Drops Consistantly with main router and 2 access point routers
Hi, I have the following setup at home: I have a main Netgear N300, router and have linked another Netgear N300 + a D-Link to extend my WiFi signal. I am using the same SSID and have done all the n...
Retired_Member
Apr 10, 2014Prior to using 5g AC intel AC 7260 I was able to move thru-out my property and home streaming a HD video ( for test only ) without any problems while roaming to 4 different AP's on 5g at 300 max rate using intel 6235.
While I can no longer roam using 5g AC I can today be connected to 1 AP and disable it and not loose a VPN to Corporate Comcast while it attaches to another AP. I believe it roamed to another AP??
