Sotmo
Mar 24, 2014Aspirant
Wifi Signal Drops Consistantly with main router and 2 access point routers
Hi, I have the following setup at home: I have a main Netgear N300, router and have linked another Netgear N300 + a D-Link to extend my WiFi signal. I am using the same SSID and have done all the n...
Sotmo
Apr 11, 2014Aspirant
searay, i have several devices connecting to the wifi network, laptops, PC's, blackberry's, Xbox, android phones and tablets and so on...when the wifi signal drops, all the devices loose connection. You get that yellow exclamation mark on the windows 7 machines, and whilst most the mobile devices are still "connected to the router" the internet connectivity is lost.
Looks like i am going to have to test with different SSID's
schumaku: Yes the idea is for all the devices to roam seamlessly by using the same SSID and security. are you saying that this method does not allow for constant connectivity to the wifi signal?
