khoff
Mar 05, 2025Aspirant
WiFi6 AX1600
My AX1600 quite providing me with extended service. not all lights were on. I called Netgear tech support and they told me I need to purchase "a plan" in order for the mesh extender to keep working. ...
Mar 05, 2025Guru - Experienced User
The forums are free here so if you want some help, we can try to help you out here.
What model NG product do you have ? RAX###
AX1600 is just a marketing speed model.
- microchip8Mar 05, 2025MasterWhere did you find this "tech support"? You most likely called one of the many NG scammers on the net. NG tech support doesn't respond like the one you called up. And no NG hardware needs to pay to function.
- khoffMar 05, 2025Aspirant
I googled it of course. The number I dialed was 888-545-9670. I gave them my serial number and she was able to tell me when I purchased it. She said my 60 days was up and that I needed to purchase a plan. I swear she jacked with my extender because I used to have 3 lights and now I only have 2.
The model # is: EAX11v2
AX1600 4 Stream WiFi Mesh Extender
Thanks.
