Retired_Member
Aug 06, 2024will it work !!!
i have a security camera, that's connected to my wi-fi. well i have it located outside my door of where i live, the walls are standard drywall, and the door is metal, and right now the signal strengt...
- Aug 10, 2024
good luck!
Hope it works well for you
Retired_Member
Aug 07, 2024yes, thank you for your answer. that's true you are correct, and yes it does work, i didn't say it was not working. but with the signal strength i am getting, as i said at 60 -70 % the camera is not working to it's fullest capability. it just need to be at a higher signal of about 85 -100 % for it to work at it's top, best performance. So as i was asking, if i move a range extender closer to it's location, will the signal be able to reach the device, through the wall and door, as i have asked. i thank you for your reply.
Aug 08, 2024Guru - Experienced User
Retired_Member wrote:
yes, thank you for your answer. that's true you are correct, and yes it does work, i didn't say it was not working. but with the signal strength i am getting, as i said at 60 -70 % the camera is not working to it's fullest capability.----What do you mean by this? I have mulitple cameras around my home and many function fine down to 20%. Most security camera's don't use a ton of bandwidth. it just need to be at a higher signal of about 85 -100 % for it to work at it's top, best performance.---it's not going to connect at 100% unless its sitting right next to the router. Wifi signals drop off quickly with distance/obstructions. So as i was asking, if i move a range extender closer to it's location, will the signal be able to reach the device, through the wall and door----Wall and door? Like extenerior wall/door? they do a great job of blocking wifi. What is your exterior wall made of?, as i have asked.----It might get a better signal but the range extender will still have a lower signal that its starting from. And single/dual band range extenders drop throughput (speed) by 50% by the very nature of how they have to work. So the camera might have a better signal, but its not necessarily going to have faster speeds. i thank you for your reply.
What actual issue are you having with the camera? You want to know specifics without telling us what issue you're having. And just saying "sure, get an extender" is easy to say but it might not fix your issue. Or might make it worse.
- Retired_MemberAug 08, 2024
yes, thank you again for your answer. i am sorry for making it sound like the issue i was having was about the camera. i was just saying. that is the device being used, in the spot of poor reception. because initially, the question was about the signal penetrating through a standard, which ever you prefer, drywall/sheetrock wall, with a closed metal door. Okay, let me try to use this approach. i live in an apartment, all on the inside, my wi-fi signal is perfect, 96-100% to all my devices, yes including my other camera's i have on the inside. but the camera i mentioned that's on the outside of my apt. door, that is on the outside of a drywall/sheetrock wall, with a closed metal door. at the signal i said before 60-70% so i was trying to simply ask if, i put an signal range extender right on the inside of this wall/door if that would improve the overall signal i would get on the device, on the outside of the door. sorry for any misunderstanding, i might have caused in asking the other question i asked. this is what i was trying to find out. thank you, i will be awaiting your reply.
- plemansAug 09, 2024Guru - Experienced User
About all I can say is you can try it. I can't say 100% that it'll help because if the signal in the apartment is 96-100% and right outside where the camera is, its to weak to broadcast, it tends to indicate something is blocking the reception. Extenders tend to work best when they're to far way from a signal, not when its attenuated by something in a wall.
but all you can do is try it. Buy from somewhere with a generous return policy and see if it works.
- Retired_MemberAug 09, 2024
thank you so much for your answer. and, oh it broadcast fine, it works fine, it's just the signal is as i said, really it varies, it ranges anywhere from 60 - 73 % the only thing i said about the camera was it has some inconsistency, being at that signal /range. thank you again for your opinion, and suggestion.
