Retired_Member
Aug 06, 2024will it work !!!
i have a security camera, that's connected to my wi-fi. well i have it located outside my door of where i live, the walls are standard drywall, and the door is metal, and right now the signal strengt...
- Aug 10, 2024
good luck!
Hope it works well for you
Retired_Member
Aug 09, 2024thank you so much for your answer. and, oh it broadcast fine, it works fine, it's just the signal is as i said, really it varies, it ranges anywhere from 60 - 73 % the only thing i said about the camera was it has some inconsistency, being at that signal /range. thank you again for your opinion, and suggestion.
Aug 10, 2024Guru - Experienced User
good luck!
