Birchy59's avatar
Birchy59
Follower
Dec 20, 2019
will not accept my wireless key
1 Reply
  • plemans's avatar
    Need a lot more info.
    you posted in the range extenders section and put in your signature the A6150, a wireless adapter.
    What are you attempting to do?
    What are you actually using?
    Where in the process is it failing? expand on this.
    The more details you get us, the more you can help. When its short and vague without even the bare minimum, its tough to help.
    so, help us to help you
    Or go to netgear.com/support/  type in your model number. It'll have install guides (some install video's too), manuals, drivers, etc.
    Or if you're within your 90 days of free support, you can click on "mynetgear" at the top, register an account and then your device. From there you can contact netgear and use your free 90 days of support.
