mnio
Apr 15, 2020Aspirant
Win 10 says EX7300/AC2200 WiFi Mesh Extender isn't secure
Hi Occassionally Windows 10 will pop up the attached notification on my screen. I believe I followed the simple instructions and am unsure what I need to do to rectify. Any hints on what I need t...
Apr 16, 2020Guru - Experienced User
On both the router and the extender?
You can log into the extender and check its wireless security settings.
any other device giving you the notice?
- mnioJun 02, 2020Aspirant
plemans, so I got kinda distracted on a few other things but regular dropouts in the last few days has reminded me of this issue. Apart from this semi-silent issue it has been rock solid until just recently.
I also have since discovered its a EX7500 with Firmware V1.0.0.52_1.0.68
As for the security settings in the extender, I cannot see any reference to Wep, wpa, wpa2 as one sees in the route documentation (https://kb.netgear.com/24096/How-do-I-change-the-WPA-settings-on-my-Nighthawk-router)
The two Lenovo Win 10 machines show the same error on each. One 2012 model and the other a 2018 model.
Appreciate any other insight you can give.
- plemansJun 02, 2020Guru - Experienced User
The EX7500 isn't a router.
here's the page for the EX6100 that walks you through the wireless settings. it should be similar
https://kb.netgear.com/24434/How-to-change-the-existing-wireless-settings-of-EX6100
