alxander_2222
Feb 03, 2025Aspirant
Windows 10 hidden network
I have 2 connections one for 2GEXT which shows but then for my 5GEXT it appears as hidden network then when I press connect it says ENTER SSID and then network security key and it says cannot connect ...
CrimpOn
Feb 03, 2025Guru - Experienced User
Assuming that the goal is to connect a Windows 10 computer (desktop? laptop?) to WiFi, it would be very helpful to know which specific Netgear product you have and how it has been configured. (Did you set up this WiFi system, or someone else?)
Orbi systems, for example, do not allow users to assign different names (SSIDs) to the 2.4G and 5G channels.
- alxander_2222Feb 03, 2025AspirantI check in the back it says model EX6110 and yes on windows 10 it only shows 2GEXT not 5GEXT and I’m guessing it’s the hidden network because this is only for my PC, on my phone it shows all network
- alxander_2222Feb 03, 2025AspirantAnd my brother set it up.
- CrimpOnFeb 03, 2025Guru - Experienced User
Windows 10 has a method to connect to WiFi using a feature called WiFi Protected Setup (WPS)
https://www.digitalcitizen.life/how-connect-windows-10-devices-wireless-networks-using-wps/
The WPS button on the EX6110 is shown on the side on page 1:
https://www.downloads.netgear.com/files/GDC/EX6110/EX6110_DS.pdf
This WiFi Extender is enabling you to connect to the primary WiFi system in the house and was probably installed because the signal from the primary WiFi system is not very good where this computer is located. Here is a link to the User Guide:
http://www.downloads.netgear.com/files/GDC/EX6110/EX6110_UM_EN.pdf
- alxander_2222Feb 03, 2025AspirantI know I can connect to the WiFi pressing WPS button but that’s works for THE 2GEXT for example I have two networks “netgear_2GEXT”,
“Netgear_5GEXT” But the 5GEXT gives better WiFi strength than the 2GEXT but, “NETGEAR_5GEXT” doesn’t appear on connections on my pc networks, only NETGEAR2_GEXT. So I don’t know if this a window 10 problem or it’s the hidden network
