dpiol
Mar 29, 2020Follower
Wired backhaul Mesh with R7800 and EX8000
I have one R7800 as my router and have a second AP using the EX8000, connected over Ethernet to the R7800. Currently the R7800 and EX8000 are using "different" SSID's! Is it possible to have the ...
Mar 29, 2020Guru - Experienced User
the "mesh" function only works in wireless extender mode.
But you can set the ssid's the same. Devices might be a little sticky but if the device is new enough, it should still roam on its own.
Have you tried that?
