mikey59
Jan 30, 2024Guide
Wired connections to AX1800 not working...
I've got an AX1800 connected to my Nighthawk mesh network & cannot get anything to connect via the LAN ports on it. WHY?!?!? Before I 'upgraded' to this mesh system, I had a WN2000RPT that was conn...
Jan 31, 2024Guru - Experienced User
and your MK system is able to see it connected?
You're able to access it using its IP address?
Are you able to log into the device and see if anythings been disabled. I don't have my EAX80 running right now but I thought there was a means of disabling the ethernet ports. It also has an access control. Maybe somethings been changed there
Just to test it, I connected my EAX80 to my RBE973S to see if it had any issues with ethernet. None at all. Once setup (using the assistant) ethernet worked fine and I could max out its gigabit connections.
So a few more questions.
1. What modem/gateway is the MK system connected to?
2. Got a screensnip of your extenders status page?
3. The wireless connections work fine on the extender?
4. Did you check the access control, scheduling, etc within the extender?
