Charlieb71
Jun 24, 2020Aspirant
Wireless Extender EX2700
I have recently changed Broadband providers and successfully connected the extender to the router, however it wont allow me to connect any devices saying the password is incorrect, I'm using the same ...
Jun 24, 2020Guru - Experienced User
What router are you connecting to?
If you setup using wps, I'd highly recommend factory resetting and reinstalling use the installation wizard. WPS gets coded differently between manufacturer's and can cause issues.
Charlieb71
Jul 05, 2020Aspirant
Thanks for replying. I’ve gone from plusnet to Vodafone routers, factory reset hasn’t worked and can’t connect it to my laptop. No idea what do do.
