pmwatts13's avatar
pmwatts13
Follower
Feb 18, 2016
Wireless Range Extender
We have a Netgear N600 router with 3 laptops, 3 cell phones and a tablet.  We have a 2 story house with a basement and are encountering dead spots in the basement and want to add a booster down there.  I see a WN3500RP, WN2500RP and an AC750 as possible solutions, but can't tell which one would be the best solutions for us.  Can anybody help?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello pmwatts13
    Any of these should work for you I would get the WN2500RP if you need the ethernet ports for stuff in the basement but if not the WN3500RP and AC750 would be good. The Ac750 is the higher end model compared to the wn3500RP and has a better range so its what will work for your budget.
    DarrenM
