GC4
Jul 24, 2016Aspirant
wireless repeater
What is the best wireless repeater that will extend through two steel doors to an in-law apartment? Thank you.
- Jul 25, 2016Your idea sounds good and definitely worth trying. Thank you very much for your help and ideas.
GC4
Jul 25, 2016Aspirant
Thank you for your response. Yes, one of the doors is a firewall door. The in-law is on a different circuit so it sounds like Powerline wouldn't work? Comcast came today and suggested that we use the repeater so no idea what to do at this point. Thanks again.
- TheEtherJul 25, 2016Guru
Well, try a repeater with large external antennas. Put it near a window facing the in-law quarters, but keep it out of direct sunlight. Then hope that it works.
