peoples44
Mar 15, 2012Follower
Wireless repeating
I have a large area to provide wireless access.. I'm using a WNDR4000 in the basement & 3 WNDR 3400v2 & 1 WNDR 3700v2. I was able to setup the 3700 as a repeater using the 4000 as a base station. When I setup the other routers as repeaters they are connected to the network but have no wireless service. They are connected to the network when I connect to the ethernet ports on the routers. But they are NOT connected by ethernet cable.
The 4000 & 3700 are NOT coonnected via ethernet cable either.
Can the 3400's act as repeaters? If so please advise what is wrong.
Should I connect via ethernet to ports on the 3400s AND the 3700. This is feasible as electricians have installed ethernet throughout the house.
- jmizoguchiVirtuosoif you read thread this well discussed
Repeat LIMITS to 54Mbps/WEP
If you looking to keep HIGH security repeats is not your options
Either buy extender such as wn2500rpt or if you can fund CAT5 cable the invet the money on run cables for SOLID connection - nwladyAspirantand halfs your bandwitdh
jmizoguchi wrote: if you read thread this well discussed
