arrbeejay
Dec 06, 2011Aspirant
Wireless router connect direct to Dynex?
Sorry if this is answered elsewhere. I have the following set-up:
1. Cable Modem
=> 2. Dynex Hub (splits signal to: 3, below; Apple TV, and internet-connected bluray player)
=> 3. LinkSys Router (RT31P2) with 2 phone ports (connects to a desktop computer, a phone, and 4, below)
=> 4. Netgear WGR614 Wireless router
Since the wireless router is last in line, the signal is not very strong. I tried connecting the Netgear directly to the Dynex, but even though there seemed to be a signal, I wasn't able to connect to the wireless router with my laptop.
There's probably somethig basic that I need to do in order to make this work. Any suggestions?
Thanks in advance for any help!
Bob
1. Cable Modem
Bob
- jmizoguchiVirtuosoIf you have have cable modem/gateway unity a wall working the what would. E an issues hooking router behind the switch despite that hooking up router behind gateway mode will be double NAT
- arrbeejayAspirant
jmizoguchi wrote: If you have have cable modem/gateway unity a wall working the what would. E an issues hooking router behind the switch despite that hooking up router behind gateway mode will be double NAT
Sorry? Seems like your post was garbled. And I don't know what the implications of being "double NAT" are; please explain. Thanks! - jmizoguchiVirtuosogoogle DOUBLE NAT.. router back to back is simply meaning of it
what is the cable modem model - arrbeejayAspirantThe cable modem is an "Arris".
- jmizoguchiVirtuosoIs this telephone capable arris modem?
Actual model of arris - arrbeejayAspirantYes, it's a phone-capable modem; I'm not currently using the cable VoIP capability, however. (We have service from Vonage.) The exact model of the cable modem is Arris TM 802. Thanks!
- jmizoguchiVirtuosoThen you can not place switch directly behind arris modem
Arris modem-> router ---> switch
