redfishsc
Mar 11, 2012Aspirant
Wireless router port problems: Can't use Android Market, need to open port 5228?????
My device: WGR614v10 Updated the software today to latest software. Problem: I just got this router used from a family member--- it works fine for general internet browsing and Youtube, etc.......
jmizoguchi
Mar 11, 2012Virtuoso
you should enable uPnP in the router setting and should able make connection when need it. but for porting the rules use portfowarding and NOT port triggering and disable uPnP. using both at same will cause issue
