GBfromSEA
Jan 05, 2011Aspirant
Wireless Setup Issue - WPS in Progress
I'm a consultant. I was trying to setup a WNR3500 (I believe that was the model - just purchased today at Bestbuy) and it wouldn't allow me to save any changes to the SSID field or WPA security settin...
jmizoguchi
Jan 05, 2011Virtuoso
WPS does not clear
WPS is easier to setup with WPS compatible Wireless adapter.
so WPS and regular encryption connection works in two ways. ONLY the SSID are obviously same.
make sure you are using PC with IE browser ...
