GBfromSEA
Jan 05, 2011Aspirant
Wireless Setup Issue - WPS in Progress
I'm a consultant. I was trying to setup a WNR3500 (I believe that was the model - just purchased today at Bestbuy) and it wouldn't allow me to save any changes to the SSID field or WPA security settin...
jmizoguchi
Jan 05, 2011Virtuoso
It just would not allow me to save any changes to the Wireless Setup without giving me the message actual text was "WPS process is in progress,
assuming this is wifi device side?
try avoid the setup and get out where you are at. Go to the netgear utility after you exit out and re-scan the network and try to connect.
