npapapicco
Feb 21, 2012Tutor
wireless stations continually loose connection to WG103
Hello, it is really a strange issue with the WG103 access point. All wireless stations in our office are continually disconnected, many times during office hours, from the WG103. Link goes down and up...
Shamonee
Feb 27, 2012Aspirant
Im having the same issue, 5 x WG103 installed and only one is playing up
Been told to save configuration
Active Reset
Reload Configuration
Try that
If fails Update F/W
it that fails RMA it
Active Reset
Try that
If fails Update F/W
