kevinz
Oct 01, 2015Aspirant
Wirelss Reapter support booadcast
Hi, I'm looking for a AP which can attached to existing LAN, and a repeater (or extender or bridge?) to connect to AP at about 50 meter distance. AP and repeater can directly facing each other, but...
- Oct 05, 2015
Yes, IP broadcasts will traverse across separate SSIDs that are in the same IP subnet.
nhann
Oct 05, 2015NETGEAR Employee Retired
Hi kevinz,
Please see and compare the WiFi capable range extenders to see which fits your requirements:
http://www.netgear.com/home/products/networking/wifi-range-extenders/
If the area that you need extending is also in the same electrical circuit as your router, please also see the Powerline products:
