kevinz's avatar
kevinz
Wirelss Reapter support booadcast
Hi, I'm looking for a AP which can attached to existing LAN, and a repeater (or extender or bridge?) to connect to AP at about 50 meter distance. AP and repeater can directly facing each other, but...
  • TheEther's avatar
    TheEther
    Oct 05, 2015
    Yes, IP broadcasts will traverse across separate SSIDs that are in the same IP subnet.
