Adamkelt
Oct 07, 2011Novice
WM3000RP keeps dropping my connection
Hi all - For a few weeks, I've had a WN3000RP Wifi Extender, and when it works right, its fantastic. However, every so often, I'll have to reset it to enable internet connectivity on it. The _EXT...
jmizoguchi
Oct 13, 2011Virtuoso
check any channel interferences on wifi which you need to change linksys and/or distance between the two devices has signal drop could have cause erratic behavior
use channel 1,6,11, 13 (13 for asia/europe user)
