505admin
Nov 09, 2010Aspirant
wms5316 and wndap350
New wms5316 New wndap350’s Old wg302v2 The wms5316 detects the wg302 and does not detect the wndap350. The data sheet shows that all functions are available with the wndap350 and is manageable. I...
Marto731
Sep 09, 2011Aspirant
Hello,
Rev 2.1.2 of firmware elimates the need to perform OUI discovery. :o
If anyone is having trouble discovering APs on 2.1.2 firmware of the WMS, please see use the following workaround.
Auto Discovery:
Only scans the default subnet of 192.168.0.0/24
IP Discovery:
Web interface>> Configuration >> Access Point Discovery>>
Must be used for any other subnet, can only scan a /24 subnet at a time.
When scanned, and Access Points don’t show up, you have to click the Access Point Discovery.
WMS5316 Firmware Version 2.1.2Release Date: 08/11/2011
http://support.netgear.com/app/answers/detail/a_id/19382
Notes
WMS5316 default IP is 192.168.0.250
WMS5316 supports configuration and monitoring of following Access Point models running at least below specified firmware versions.
a. WNDAP350: Firmware WNDAP350_V2.0.27.
b. WNDAP360: Firmware WNDAP360_V2.0.7.
c. WNAP210: Firmware WNAP210_V2.0.27.
d. WNAP320: Firmware WNAP320_V2.0.3.
e. WG103: Firmware WG103_V2.0.37.
Auto Discovery:
IP Discovery:
Notes
