mdow's avatar
mdow
WMS5316/WNDAP350 Odd problems and errors
With my WMS5316 I get an odd error in the sys log, hundreds of times per day.
Jul 29 15:41:39 wms36D5C7 user.err ap_mgr_WNDAP350: Error condition, drain the queue
Not sure the problem there... But it could be related to the following problems.
With my wireless setup, the WMS5316 and 5 WNDAP350s, I have trouble with connecting. I have seen my LED's on the WNDAP350s for the LAN turn off, then on after a few seconds. Regarding that I have seen threads here talking about rebooting WNDAP350s. I have sent a support ticket to NETGEAR for this issue.
I am having an odd issue with several devices on my network, usually IPADs though as it seems, and late nights. The IPADs and other devices will not connect. They will allow me to input the WPA key, then it will sit there, not connecting for several minutes. It finally will connect and my IPADs say they are on the network (wifi icon in upper left), but they will have no internet access. I have tried resets restores on the IPADs to no avail.
Any ideas would be appreciated.
  • Also, my WNDAP350s log me out sometimes when I attempt to maneuver through the web interface...
    Any ideas?
  • Hi mdow,
    i have observed exactly the same problem, did you solve your problem?
  • I did a factory reset on all of my wireless equipment, and firmware upgraded them all to the newest, and then did another factory reset. This combined with making separate wireless SSIDs for 2.4ghz and 5ghz radios seemed to have fixed my problem.
    Let me know if this helps.
