Pullingmyhair12
Oct 02, 2023Aspirant
WN1000RP – N150 Iphone doesn’t connect
Network is set up and the mac can connect, however when I try to connect on iPhone it buffers indefinitely.
Pullingmyhair12
Oct 03, 2023Aspirant
Okay thanks, I bought this on ebay for £12 did I get scammed?
So many wifi routers out there with so many different capabilities I just wanted something cheap and easy.
No chance of getting this one fixed for iPhones then?
Oct 04, 2023Guru - Experienced User
scammed? No.
But you bought something without knowing what you bought.
You bought a super cheap/old/poor performing extender.
It was released over a decade ago.
Expecting the same performance from gear a decade old isn't realistic.
I'd look at buying something dual band from a newer generation.
