ausnew
May 07, 2013Aspirant
WN1000RP does not connect to my WIFI router
Just purchase the WN1000RP to extender my WIFI to my second floor. Apart from my ReadyNAS, have never purchase a NetGear network device before. My WIFI router is an old DLink DIR-300, had no issue...
numcrun
Feb 13, 2014Aspirant
I had the same problem after it had worked for a long time. It has the latest firmware. I tested it at another location and it worked. But it would not see the wifi at the first location. I increased the wifi security to the highest (WPA2 or whatever) from the second highest. Just to try something. And it worked. Go figure. The auto selected channel is 2, not sure if it was the same before.
