Christianesc78
May 17, 2019Aspirant
WN1000RP does not work2 - only yellow light
My WN1000RP extender has stopped working after I change a config in its application and apply. When I tried to access again, it just turns on the yellow light, does not go green and does not appear o...
Christianesc78
I tried this and the yellow led did not even blink.
It stays always turned on and does not change ....
May 19, 2019Guru - Experienced User
something might have gotten corrupted during the changes/resets. Looks like this model is quite a bit older so I doubt its within warranty (?) Plus it doesn't have an ethernet port to force new firmware to it via a tftp procedure.
It might be time to call it and upgrade/update. Sorry I wasn't more help.
