kenrw8
Dec 28, 2013Follower
WN1000RP does not work2
These Extenders are C**P on second one and again followed instructions i.e plug in, press WPS button, press WPS on router (Netgear DGND3700) waited, entered router SSID and password (manually as it d...
Pishaw
Aug 19, 2014Aspirant
So your solution is a link to the instructions? Good lord.
The instructions work fine. It's the EXTENDER that doesn't work. Everything in the setup goes fine until you try to connect to the extender after establishing the network. At that point, it will allow NOTHING to connect to it.
Is the WN 1000RP trash by design?
