Pulpman
Oct 30, 2013Follower
WN1000RP doesn't work
Hi guys,
I just bought this device and i have to say that it doesn't work and i don't understand why.
I tried using the WPS button, on the booster and than clicking the one on my access point, but the booster can't link to the net.
So i tried in the manual mode connecting to NETGEAR_EXT and than using the website www.mywifiext.com but still doesn't work because the booster can't see the wifi of my house, i mean that there isn't on the wifi list of the booster.
Somebody can help me somehow?
Thank
Thank
- GammawareAspirantHi !
Which wifi networks do you see on your pc?
Regards
Gammaware - Retired_MemberMove closer to router try again, does the connection status between router and extender show green? If pc cannot see WIFI with good signal then WN1000RP will not either.
[FONT=FuturaBT-Medium][SIZE=1][FONT=ArialMT][SIZE=3][FONT=ArialMT][SIZE=3]WPS does not support WEP network security. If you are using WEP security, use Option 2 to connect.
[/SIZE][/FONT]
[/SIZE][/FONT]
[/SIZE][/FONT]
