bouch
Dec 16, 2021Aspirant
WN1000RP No internet
I have a Huawei Router Model HG659
I followed the Netgear Genie instruction for Web browser set up after doing a reset on the extender. This was done with the extender next to my router. I receive a stong wifi link and shows that I have connected but with the message "Connected without Internet" I have repeated the process numerous times with the same result.
I have another Wifi extender already connected in another room and this works ok. It is labelled NETGEAR_Ext. The label on the WN1000RP was given "NETGEAR_EXT" in the process. I would be gratefull for any suggestions.
Where do you see this message?
It may be that the extender is working as expected but the client that shows that message is blocking the Internet access for security reasons. For example, if this is an error in Windows, the problem may be in Windows.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.- bouchAspirant
Thank you for your reply. I have read other posts relating to this extender but have not found a solution.
The message "connected without internet" is shown when connecting my tablet to Wifi Netgear_EXT. This also occurs when connecting via my Samsung A52 mobile.
I have also tried connecting via WPS and the 3 green lights blink but nothing happens when pressing WPS on the router(Extender next to router).
When logged on the WN1000RP shows up on my devices connected to Router using WiFiman but I do not get internet connection. The Link rate LED at the top stays off.
