Robert4723
Feb 20, 2013Follower
WN1000RP vs WN3000RP
Does anyone know the difference in the WiFi Booster vs the WiFi Range Extender? The spec sheets do not make a clear distinction and there is a big difference in pricing. All I want to do is improve...
foolishstar
Jun 05, 2013Aspirant
ausnew wrote: I just purchased the WN1000RP for the exact same purpose and so far have found it to be perfect. When I move between floors my iPad will connect to the main WiFi router or the WN1000RP without any intervention, no downtime!
Do you have Apple TV? If so, could you test it with your iPad attached to the WN1000RP and your Apple TV attached to your LAN or primary SSID Transmitter?
Hope you can help, I have problems with it and nobody wants to help :*(
Thanks, Foolishstar
