bmn46
Aug 30, 2014Aspirant
WN1000RP vs WN3000RP
I have a dlink N300 router. I am currently using the WN1000RP extender which is N150. Is there any advantage to changing over to an N300 extender, either the WN3000RP or the EX2700? The current ex...
bmn46
Thank you, that is what I had suspected, the limiting factor is the speed from Telstra, which of course is woeful at 6.5mbps and whether it is N150 or N300 makes little difference when it just being used to surf the internet, Roll on the NBN. Not using for media streaming but interesting to know that between devices on the LAN is where the difference is seen.
I knew that extenders halved the speed, but I thought that the N300 might extend the range and push the signal further. The N150 works ok, but still has trouble reaching all spots in rear family room from router at front of house.
