bmn46
Aug 30, 2014Aspirant
WN1000RP vs WN3000RP
I have a dlink N300 router. I am currently using the WN1000RP extender which is N150. Is there any advantage to changing over to an N300 extender, either the WN3000RP or the EX2700? The current ex...
fordem
Aug 30, 2014Mentor
The difference between the N150 & the N300 is probably the number of "streams" - wireless-n uses multiple "spatially separated" streams, up to I believe a maximum of four, it's theoretically possible that with two streams traversing slightly different paths you could see better coverage, but I wouldn't bet on it.
The range issue is, so to speak, one affected by "the laws of physics" - the attenuation of the signal by distance and the materials used in the construction of your home - if you want to see an improvement there, find a way to reduce the distance - for example - relocate the router to a more central position - or - if you willing to spend the money, install a wireless access point, and cable it back to the router.
The problem with wireless routers is that they are designed for convenience, so you have a router, a switch and a wireless access point, which ends up being located in a corner, convenient for the cable runs, but less than optimal for wireless coverage - the way around this is to use a wired router which can sit in the corner, with a wireless access point that can be optimally located - which is how I have done it - one single ΒΌ" Ethernet cable runs to the access point, and provides both power (PoE) and data.
