rpz620
Nov 09, 2010Aspirant
WN2000RPT - Internet Access Keeps Dropping
All of my devices can continually access the WN2000RPT device and access the local network as well as the internet. However, after some time, the internet connection drops for the repeater only - I c...
rupert1020
Nov 09, 2010Tutor
rpz620 wrote: agree on the need for a fix - it's basically a brick until they fix this.
Is there a simple way to check?
Assuming a reset of the repeater gets fresh IP's for all connected devices therefore leaving no conflicts until hours or days later when other devices come online.
Actually, it's the router that distributes the IP addresses. The WN2000RPT has an internal DHCP server which can be turned on. I had to turn mine off because it was sending out IP addresses to the attached devices which sometimes created conflicts.
See the FAQ for more information on how to turn the DHCP server on/off
http://kb.netgear.com/app/answers/detail/a_id/14239
Depending on your router you can check the ip/mac addresses from a web browser. With Netgear routers use 192.168.1.1 by default. I have a WNR3500L with dd-wrt running on it. I upgraded the original firmware on the router thinking it was the source of the problems. Although the drops are much less frequent now with dd-wrt installed, I still suspect the repeater (WN2000RPT) to be causing the drops.
