rpz620
Nov 09, 2010Aspirant
WN2000RPT - Internet Access Keeps Dropping
All of my devices can continually access the WN2000RPT device and access the local network as well as the internet. However, after some time, the internet connection drops for the repeater only - I c...
Loudog2
Nov 22, 2010Apprentice
I set up a static IP for the device and router. It shows up if nothing is on that is wired to it(back of 2000). But if something is turned on through the 2000 it shows a different IP and doesn't show the static I gave the device/router. Power cycling does help for a bit, then back to signal drops.
