rpz620
Nov 09, 2010Aspirant
WN2000RPT - Internet Access Keeps Dropping
All of my devices can continually access the WN2000RPT device and access the local network as well as the internet. However, after some time, the internet connection drops for the repeater only - I c...
arsenal_fan
Jan 11, 2011Aspirant
Thanks for the detailed analysis Ondart. I ended up doing exactly as you said, but I'm not using a Belkin but rather a Netgear router. I set it up the channel for auto and everything seems to be working much smoother.
I was getting intermittent loss of connectivity to the router for 4-6 seconds. Then all of a sudden I couldn't connect to the Internet at all. I reset the bridge and went through the same setup as I had previously done to no avail.
If anyone else is having issues, I would recommend testing different wireless channel settings as Ondart described. It seemed to have been the culprit in my case. I'll keep you guys posted though if I continue to have any issues. Crossing my fingers though! :)
Bobby
Bobby
