rpz620
Nov 09, 2010Aspirant
WN2000RPT - Internet Access Keeps Dropping
All of my devices can continually access the WN2000RPT device and access the local network as well as the internet. However, after some time, the internet connection drops for the repeater only - I c...
DJReignx
Apr 07, 2011Novice
OK the past post....worthless....I have since started dropping signal again even though my HTC isn't connected...The only thing I suspect is the other members in the household with smartphones that are still connected to it...
The reason I was so convinced about the phone wifi effecting it was because when i originally bought it...it went 3 weeks without EVER dropping a signal...until I connected the HTC...that's when all hell broke loose and it started dropping every 10 minutes like clockwork...sometimes 10 times in 10 minutes...So back to square one here...Any advise would be helpful...let me know about the smartphone wifi if anyone tries that... Definitely not a fix but did extend my drops significantly...now I drop every 2 to 3 hours instead of every 10 minutes...
