rpz620
Nov 09, 2010Aspirant
WN2000RPT - Internet Access Keeps Dropping
All of my devices can continually access the WN2000RPT device and access the local network as well as the internet. However, after some time, the internet connection drops for the repeater only - I c...
James_NOT_Bond
Jun 17, 2011Novice
Ondart wrote: I have resolved this issue. My Netgear WN2000RPT Bridge would disconnect randomly from my DLink DGL-4500 Wireless Router. The lights on the bridge always stayed green when this happened and it would occur about every hour more or less. All wireless and wired devices on the bridge would still be able to ping each other but no internet access was available. All wireless and wired devices on the Netgear router could ping each other and could access the Internet. The connection between the bridge and the router was the problem.
Looking at the router statistics, i was able to tell that the bridge MAC address was registered properly on the router as an active connection but the connection was not functional. I decided to start changing the Wireless Channels, there are 12 channels in the 2.4 GHz band for 802.11N. I started with channel 1 and I was suddenly able to ping a device on the bridge. I began with copying a 100MB file over the bridge to the remote device. Within 5 min, the connection would drop. I kept changing the channel until the bridge stopped disconnecting. I ended up setting the router to "Auto Channel Scan". This also worked so I left it at that. It's been up 24 hours now with heavy traffic over the bridge and no drops.
I found another problem and this is likely the root cause. I have an RF Logitech MX mouse and RF keyboard. Mousing around was intermittently jerky and keys would not consistently function properly when heavy traffic, i.e. copying a 100MB file over the bridge, was performed. I changed the router to each of the 12 channels on the 2.4GHz band with no change. When the traffic was low from the router to the bridge, the keyboard and mouse issues would go away. So i have a conflict on the 2.4 GHz band and the darn Logitech RF devices are not channel configurable unfortunately. I don't want to replace my $180 keyboard/mouse combo so I am not sure what to do about it yet.
Here are a few other things I did during troubleshooting that may also be of some help:
- Turn off DHCP on the Bridge (http://www.mywifiext.net/cgi-bin/hidden_dhcpd.html)
- Configure the Bridge with a Static IP address, i.e. 192.168.0.10.
- Change the wireless range on the Router to something like 192.168.0.100 - 192.168.0.200 for DHCP clients and set the Bridge to use a range of 192.168.0.201 - 192.168.0.254. This will prevent DHCP IP conflicts.
- Hard code devices that you want to have the same IP addresses in the lower range on the router, i.e. 291.168.0.2 - 192.168.0.99 for example.
Anyway, I struggled with all this and these changes resolved my problems. I hope this can help others with the same issue.
Got any ideas about my RF keyboard conflict? Please speak up!
Joe
hey buddy, u're pretty smart....it is truly important for every wireless devices to change the proper wireless channels or remove radio interference objects to get a stable wireless connection...
